Panel Images
Re: Panel Images
Postby N111YX » Mon Sep 03, 2012 5:35 pm
"Budget"? It appears that you have all of the most expensive boxes...;)
Kip
Jabiru 3300 #1637 and #3035
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1175 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Re: Panel Images
Postby Bryan Cotton » Thu Feb 09, 2017 10:56 pm
Here is where I am going. I'll try not to fly sideways though.
PDF panel 191YX.pdf
191YX panel sketch
(162.08 KiB) Downloaded 828 times
Re: Panel Images
Postby NWade » Fri Feb 10, 2017 2:23 am
I'm trying to keep things simple with my panel. Should have everything I need to fly Day & Night VFR with reasonable cross-country legs.
Not pictured:
Dual USB jack for power/charging (will be mounted just below the panel)
Headset jacks (will be mounted behind the shoulder)
Transponder (mounted in aft fuselage, controlled by iEFIS)
Throttle & mixture (mounted on Sonex throttle quadrant, above flap detents)
--Noel
Sonex #1339
TD, AeroVee Turbo, Center-Stick, Acro-Ailerons, Flush Pulled Rivets
Sonex 1339 Panel Layout
NWade
Re: Panel Images
Postby jjbardell » Fri Feb 10, 2017 7:18 am
Noel, have you thought about mounting your ELT remote switch behind the pax like your headset? I found it saves panel space and is still accessible.
N83LJ - Sonex #0864 (SOLD)
jjbardell
Re: Panel Images
Postby Bryan Cotton » Fri Feb 10, 2017 8:50 am
Looks good Noel! The modern panels are very space efficient when thought out. My panel is a hodgepodge of stuff I had, plus I bought a G meter and turn coordinator. I have less than $2K in mine, the bulk of it in the KX155.
One nice thing about center controls, it will be easy to mount my Anson Engineering vents to either side. I am going to let them blow up from underneath.
There are a couple typos in there. Too many r's in cooordinator and I plan on a 10A breaker for the ignition per the plans.
I bought my lighter plugs from the aviation aisle at Farm & Fleet.
Re: Panel Images
Postby Fastcapy » Fri Feb 10, 2017 12:44 pm
Mike Beck
Oshkosh, WI (KOSH)
Sonex #1145 N920MB
Fastcapy
Re: Panel Images
Postby mike20sm » Fri Feb 10, 2017 1:23 pm
What's this thing do?
Standard Sonex kit #1692
mike20sm
Re: Panel Images
Postby vwglenn » Fri Feb 10, 2017 1:35 pm
I think the KISS method works. My panels has the MGL Enigma and I like it but the interface is too clunky in my opinion. I think a simple engine monitor and some steam would've been just fine for the flying I do.
If I were to put a USB Jack in, I'm thinking of mounting a USB plug in the top of the panel so I can plug my ipad/GPS/ADSB reciever in so the cords don't hang down in front.
Glenn
Sonex #600
N889AP
vwglenn
Re: Panel Images
Postby Fastcapy » Fri Feb 10, 2017 5:22 pm
That's the Surface to Air Missile Alert system!
Actually, it is the ELT remote panel.
Mike Beck
Oshkosh, WI (KOSH)
Sonex #1145 N920MB
Fastcapy
Re: Panel Images
Postby sonex892. » Sat Feb 11, 2017 12:26 am
Glen.
What is the bar LED next to the ASI?
Steve
Lazair kit 1981 sold
Sonex kit 2010
Sonerai 2LS project rotax 912
sonex892.
Return to Panel
