by WaiexN143NM » Fri Feb 03, 2017 10:56 pm
Hi bryan,
Yes the knob will be tight to rotate. One solution would be a little knob from the hardware store mounted on the big red knob to help rotate it. What we did was remove the big red knob and replaced with a window crank. Same size shaft . Works well. Another thing we did was to hinge the inst. panel on the bottom , it folds out while your sitting in the plane on the nice soft cushions. Very easy ro work on stuff. Yes , its a structrual piece, so the lower piece we installed a heavy alum. angle.to beef it back up. We then used that angle to mount the toggle switches. Trust me, you dont want to be upside down and twisted around. Too old and too much arthritis for that nonsense. We love the fold down panel. You just have to watch the length of items , cables, coax, harness etc , so it can hinge and clear.
Keep us updated. Looking forward to seeing you and adam on the flightline at osh 17! Hopefully , wayne will put up with us again!
WaiexN143NM
