I did exactly what Peter suggested. Let me try to break it down in a bit more step-by-step detail, in the hopes that it will ease your frustration:
- Use a sharpie to mark the centerline of the rib flanges (this is where the rivet holes should be drilled through)
- Use a sharpie to measure and mark the rivet hole locations on the flap skin
- For each flap rib, look at the front face of the flap (where the skin overlaps itself)
- On the larger part of this front face (where there is no overlap), drill 2-3 of the rivet holes with your pilot bit (#40) but skip the one where the skins overlap (you will wind up drilling holes later through your hinge material).
- Pilot-drill the top & bottom flap skin holes - be careful not to punch through so hard that you drill into the skin on the opposite side. Putting a piece of wood inside the skin to "back up" your drill is a good idea. (See the steps below for how to get inside the skin)
- Gently lift up on the overlapping skin to "peel open" the flap skin. Don't bend it too hard or too far or you may crease the skin, but you should be able to pull it open plenty wide-enough to slip the flap rib into position.
- You might want to use some small wood blocks to hold the skin open by a few inches. This will let you use small clamps to hold the flap rib forward against the face where you drilled the pilot holes.
- Line up the flap rib so that your centerline mark is visible in the pilot holes on the front face of the flap skin.
- Clamp in place, and drill through these holes in the front face, cleco'ing as you go.
- Now your flap rib is pretty securely held in-place at the front face. You can use a broom-handle or other long tool to push or pull on the trailing edge of the flap rib to get the centerline marker to show through in the pilot-holes you drilled in the top & bottom flap skin.
- Working from front to back, nudge the rib into position, then you can "pin" it in place by gently pressing with your fingers about 1" on either side of the flap rib ("trapping" the rib flange in the middle with downward pressure on the skin). Pilot-drill the hole and cleco it in place.
- As you work towards the trailing edge, the rib should naturally start to line up better and better (although with a shorter bending length it will also get stiffer - so its important to be pretty accurate with the first few holes, to set yourself up for an easier time later on.
Hope this guide helps you in your build!
--Noel
Sonex #1339
