MichaelFarley56 wrote:Oh, one more thing...the next time you take the wings off, use that opportunity to drill out the pulled CCP rivets that may interfere with the spar bolts and nuts, and re rivet them from the inside out. Maybe six per side, three in front of the spar and three behind. The wing covers them up and doing that will prevent clearance issues. Also learned that one the hard way.
Good luck!
142YX wrote:ps. Something that i did right was ream out all of my 1/4" bolts using a .248" reamer. Makes a perfect hole for most AN-4 bolts.
dbdevkc wrote:Nick - Oh man, I feel your pain... I know the feeling when you are far along in a part that took a lot of time to make and you screw something up.
Do you think that had you drilled the hole to a size closer to your final reamer size you would have had better luck with the reamer? My understanding is that you should only be attempting to take off a few thousandths with a reamer. So, for example if you had used a 9.4 mm twist drill (.3701") then used your .374 reamer do you think it might have worked better - trying to take off only .0039?142YX wrote:ps. Something that i did right was ream out all of my 1/4" bolts using a .248" reamer. Makes a perfect hole for most AN-4 bolts.
Thanks for this info.
falvarez wrote:Right or wrong, I was taught by a sheet metal worker that a reamer is only to be used in one direction (in or out of the hole), not both like a drill bit. What I've done, and it prevents me from using to big of a reamer, is I insert the reamer end (the end that gets chucked) through the hole first, then attach it to my drill, then pull it straight out. I ream all my bolt holes and I've had good luck with this method...as I've said before, I tend to do everything the hard way.
falvarez wrote:Mike, can you clarify what rivets you would redo? My plans show the first few rivets on the spar tunnel are solid rivets that get driven flush...all rivets on my tunnel sides are flush...so I can't visualize which ones you are saying to change.
radfordc wrote:I bought a plane that had loose wing bolts due to oval holes. You could move one wingtip up and down an inch. The fix was to up drill to a 7/16" bolt. Kerry said that you could go as large as 1/2" as long as the hole was centered properly in the block. I used a hand drill and drilled up in 1/32" increments like you did, but made the last hole 1/64" smaller than the reamer. I also used copious amounts of WD-40 as a lubricant. The final holes were very snug...you have to tap the bolts with a mallet to get them to go in. It can be done.
You can also find horror stories of people who used the pilot drill and had screw ups.
Users browsing this forum: Google [Bot] and 82 guests
