kevinh wrote:HI ya'll,
So I have Peter's nice NACA vents. And I could swear I remember a place in the plans where Sonex shows where to cut the vent locations. Alas, I must now be blind because I can't find the right sheet. Anyone remember where it is?
Kevin
tonyr wrote:Kevin,
No dimensions as such, but as high and as far forward as you can get them without interfering with any surrounding angles, tank etc.
(In the section just behind the vertical channel that supports the rudder block brackets)
Cheers
Tony
Sonex1243 wrote:Hi Kevin;
Plans sheet SNX-F13 shows the cutout detail for mine. Not sure if it would be the same sheet for your WX though.
