by Bryan Cotton » Tue Jan 17, 2017 3:02 pm
Jake,
There are no pilot holes, but the motor mount has a tube welded to the big tube that holds the gear leg. I inserted the gear leg, ran a drill down the little tube and made a mark where the hole needed to go. Then I pulled the gear leg out and drilled the hole through on the press and V block. Gear leg went back in and I punched the hole through to the back side of the gear mount tube. The axles are a different set of holes and there is tooling in your kit to set toe in. The procedure is similar.
