Sonerai13 wrote:I was part of the fact-finding team, and had input into the factual report. (Some of which I do not specifically agree with, even after giving my input.) I was not part of the NTSB headquarters panel that took the factual report and issued probable cause determination. I am only reporting what I saw during the physical inspection of the wreckage. I do not make any claim to doing any analysis or cause determination.
Sonerai13 wrote:We did not find any physical evidence of a turbocharger failure, either partial or complete. I can not be any clearer than that. If you are not willing to accept my "eye witness" report of these facts, that's your problem, not mine.
The engine's turbocharger would not rotate
Sonerai13 wrote:I can only report what I saw. I an not "responsible" for anything other than that.
sonex1374 wrote:Dale,
You just don't get it, do you.... The damage to the turbo was caused by the crash impact forces, and yes, after the crash the turbo wouldn't rotate. What's so difficult to comprehend about this? You seem dead-set on twisting the NTSB report around to insist that the Turbo wasn't rotating BECAUSE it was damaged. The investigation notes and pictures of the turbo clearly show damage to the housing by the impeller wheel impacting it.....as in impacting during the crash. You are confusing cause and effect here. The turbo would not rotate because it was damaged in the crash!
Instead of accusing Joe of incompetence or of covering up the truth why don't you show him some respect and listen to what he's saying. My money's on Joe, not an arm-chair mechanic.
because that is a direct contradiction to the report ... if you read it. From the report, and I quote:sonex1374 wrote:the damage to the turbo was caused by the crash impact forces
It could not be determined whether the turbocharger would not rotate due to impact damage or whether it seized in flight resulting in a partial loss of engine power.
The damage to the turbo was caused by the crash impact forces, and only after the crash the turbo wouldn't rotate. The investigation notes and pictures of the turbo show that the damage to the housing was caused by the impeller wheel impacting it during the crash. The turbo would not rotate simply because it was damaged in the crash! The rest of the investigation showed no pre-impact turbo anomalies. The NTSB report could have been much better here, and Joe is trying to clear up any misunderstandings.
radfordc wrote:Direct C51 wrote:So what's the plan here? keep selling engines that have an unknown flaw? Keep offering transition training in a fleet that has seen like a 25% failure rate? Forget about the B model, the jet, and any future projects. Shouldn't figuring out the flaw in your current product be absolutely paramount? It's not like this is a crank failure that has been identified and addressed. It's an unknown flaw and every Arrovee is possibly susceptible. Am I wrong in thinking this?
The Aerovee is a VW engine. VW engines have been modified for aviation use for going on 70 years or so. Lots of VW aviation engines have failed...with and without turbocharging.
Your suggestion seems to be to stop selling the Aerovee engine? What about alternatives? The Jabiru has had it's share of troubles and failures. The Corvair engine is noted for breaking crankshafts...at least they once were. Name an engine and someone has had a failure....Lycoming and Continental included.
Experimental aviation is a different breed of cat. You are the manufacturer and certify that the plane is airworthy. If you're not up to that then Cessna and Piper have some nice offerings.
lpaaruule wrote:Just an observation
I noticed in the picture of the mixture control, that right next to it is the button that activates the smoke system. I could imagine it getting bumped during a rush to grab the mixture control. It's in the off position in the picture though. It it were on for a second or so, maybe that's where the smoke came from?
Users browsing this forum: Google Adsense [Bot] and 4 guests
