I'm convinced it's happening because there is no braced connection between the upper and lower engine mount arms. The engine is pivoting on the upper arms and that's banging the lower rubber mounts into the lower mount pins, elongating the holes and the rubber mounts.
I think adding a brace between the upper and lower arms would solve everything, since the engine could not pivot any more. But I'm not a skilled welder and haven't wanted to do the major surgery to have someone else do it.
So another AeroVee guy made a couple of molds to match the shape of the rubber mounts, and then he and I experimented with different polyurethane mixes to get something firmer than the factory mounts. I then used shorter engine mount bolts than on the plans, since the ones sized per the plans will allow the nuts to bottom out on the shoulders of the bolts, making you only "think" you have the nut as tight as it can go on the mounts.
What we used: PMC-780 DRY which is a Shore 80A liquid rubber formulated for making industrial parts. It came from Mold Making & Casting Materials | Rubbers, Plastics, Foams & More!,
https://www.smooth-on.com/Doing some internet searching I was looking at these sources for polyurethane:
https://www.summitracing.com/parts/tes- ... gJbpfD_BwEhttp://www.reynoldsam.com/product/reoflex-series/http://www.energysuspensionparts.com/diymmihttps://www.mcmaster.com/#catalog/117/3599/=fnz7bthttps://www.smooth-on.com/products/reoflex-60/From last year to this year (annual to annual) my engine shifted a bit, but not a lot. I put a jack under the engine and took the weight off the mounts, then recentered and retightened the rubber mounts and the nuts.
I have scale drawings of the rubber mounts if anyone wants to make their own molds.
