by mike.smith » Mon Jan 02, 2017 9:47 pm
I don't know about everyone else, but I wish I had cut something like 1/4" off the length of my axle bolt before I drilled and tapped it. The axle assembly is wider than the inside of the wheel pants, so the pants have a pronounced bulge where the end of the axle presses against the outer half of the wheel pant. Very annoying for putting the pants on, and just looks wrong.
As for tapping, do just as you suggested, and stop shortly after each new resistance. Back out a half turn, then go at it again. It will take a while, but that's OK. Taps are hard but brittle, so go slow.
