Cotton AeroVee 0795
Re: Cotton AeroVee 0795
Postby Bryan Cotton » Sat Dec 17, 2016 5:55 pm
We now have evey form of loctite and permatex known to man. I am starting to believe that Aeroconversions is just a front to push their product.
Accessory plate in place.
We are cruising. Headed back over with Matthew to work on the new hovercraft project.
Postby ScottM-Sonex1629 » Sat Dec 17, 2016 7:00 pm
You're so close to installing the engine! Do you have all of the items on the firewall yet? Battery box, coils, grounding tree, etc?
We installed my AeroVee the same way (accessory plate on the engine mount), then two of us lifted the AeroVee up to the X-plate and a third person threaded the bolts on. 5 min job!
Scott Meyer
Sonex 1629 - Sold...9/2019
ScottM-Sonex1629
Postby Bryan Cotton » Sat Dec 17, 2016 9:38 pm
Scott,
I have nothing on there yet. I need to figure out where to put everything in case I want a turbo someday. I've lined up a cherry picker so we can put it on by ourselves.
Postby Bryan Cotton » Mon Jan 02, 2017 1:07 am
Test of postimg.org:
Postby Bryan Cotton » Mon Jan 02, 2017 8:46 pm
We got our nutplates installed for the coils, VR, and battery. Back:
Front:
I discovered my hardware kit does not have the engine mount bolts. Bummer!
Postby Bryan Cotton » Wed Jan 04, 2017 12:06 am
Coils and VR bolted on:
Postby Bryan Cotton » Mon Feb 04, 2019 11:29 pm
All,
There are two threaded holes we are pointing to in the picture. I assume this is a bug thing for mounting the fan housing or something, and I don't need to worry about them. Is this right?
Also you can see the supports for the hard lines. Soft lines from the back of the engine to the filter.
There is a large opening to the sump in the front right corner. Would that be a suitable alternate location for the oil sender or will it not be in the oil for climbs and 3 point attitude?
Postby MichaelFarley56 » Mon Feb 04, 2019 11:47 pm
Hey Bryan,
The two holes you’re pointing to are for automotive installation stuff and you won’t need to worry about them. I can’t quite see where you’re talking but there is an opening on the left (pilot side) side of the oil pump that’s open to the sump. This is a pretty standard location for your oil temp probe; the AeroVee manual gives you directions on how to drill and tap into the red block off plate for that spot so you can add the oil temp sensor. That’s where I have mine and it works great.
Is that what you meant? Looking great!
Postby Bryan Cotton » Tue Feb 05, 2019 7:28 am
Thanks Mike!
Postby peter anson » Tue Feb 05, 2019 8:53 pm
We now have every form of loctite and permatex known to man.
I'm afraid that's not possible Bryan. While in fact there are only four types of Loctite; blue, red, green* and yellow; they put them in so many different numbered bottles that it is physically impossible to buy them all because no single retail outlet can be bothered stocking the complete range. Not only that, but they only have a one year shelf life so that when you are using them on something that really matters, like an aircraft, you are forced to buy the same ones over and over.
* Green Loctite is just blue and yellow Loctite mixed together.
peter anson
