SNX-F21 detail E
SNX-F21 detail E
Postby lstinthot » Sun Jan 01, 2017 3:08 pm
Im working on the upper cross tie bolts that are inside the box. The bolts coming down into the box from inside the plane are what im looking to put the final bolts in. Why do the plans call for AN 7A bolt and 2 washers on each hole? Wouldn't a AN-6A bolt with one washer work good? Are people putting a washer on top and one on bottom? The sites I looked at could not make out these bolts real good.
Thanks
Mike
Scratch building #1604
Tail dragger
Thinking Turbo Aerovee
lstinthot
Re: SNX-F21 detail E
Postby Bryan Cotton » Sun Jan 01, 2017 5:12 pm
Mike,
In my opinion many Sonex callouts are one size long. I have often gone down a size because I am nuts about that sort of thing. But, two washers won't kill anything.
Postby kevinh » Sun Jan 01, 2017 5:52 pm
yep - I used -6 bolts, with two washers on the aft bolt, and one on the forward bolt (because that's what a test fit showed would work). The aft bolt has one less layer of 0.025" to fit through because of how the box is built.
kevinh
Postby lstinthot » Sun Jan 01, 2017 10:53 pm
That is what I was thinking. I have been putting double washer on many parts.
Tail dragger
lstinthot
Postby sonex892. » Mon Jan 02, 2017 2:51 am
lstinthot wrote:That is what I was thinking. I have been putting double washer on many parts.
I believe up to 3 washers under the nut is acceptable practice. That said, before starting I had every size needed per the plans. I had to order more hardware to comply with the 3 or less washer rule.
Steve
Sonex 892
Steve
Lazair kit 1981 sold
Sonex kit 2010
Sonerai 2LS project rotax 912
sonex892.
Return to Sonex Plans
Users browsing this forum: No registered users and 37 guests
