Stock tailwheel pushrod
Re: Stock tailwheel pushrod
Postby Bryan Cotton » Fri Dec 16, 2016 9:23 pm
I have my mixer locked in place, mini rudder in place and my cables are adjusted and pinned. The pushrod does not seem close. I was thinking rod ends, but weight is the enemy and some of you seem to have done fine with the stock setup. I am thinking of welding up one that fits rather than doing some crazy S bend.
Postby Bryan Cotton » Sat Dec 17, 2016 5:49 pm
Here is my pushrod:
I have 4130 stock and have started to fabricate one that fits.
Postby Corby202 » Sat Dec 17, 2016 7:37 pm
I kept the stock pushrod because of weight, I fitted bushes each end 65 hrs, so far so good.
Phil
Phil Bird
Sonex 759 JAB 2.2 Tailwheel
Mittagong NSW Australia
Corby202
Postby Area 51% » Sun Dec 18, 2016 11:07 am
What keeps the motion of the tailspring from transferring to the rudder horn and causing it distress with the stock unit? It seems heim joints would be a requirement in this application.
I believe I saw Ryan had to put a significant bend in his rod to get the flanges to line up.
Area 51%
Postby N111YX » Sun Dec 18, 2016 12:25 pm
This the reason that I went with the rod end option. I had heard, but not personally experienced, that the steel bolts could elongate the aluminum holes after use. Since lots of shock is transferred through these pieces with every imperfection of an operating surface, I would guess that soft field/grass operators would see the most benefit.
Mine is as new after 960 landings with perhaps 20 or so of those on grass :D
Area 51% wrote:What keeps the motion of the tailspring from transferring to the rudder horn and causing it distress with the stock unit? It seems heim joints would be a requirement in this application.
I believe I saw Ryan had to put a significant bend in his to get the flanges to line up.
Kip
Jabiru 3300 #1637 and #3035
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1175 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Postby mike.smith » Sun Dec 18, 2016 2:22 pm
I did the rod end bearings:
http://www.mykitlog.com/users/display_l ... 803&row=71
I later made a new pushrod that had and "S" bend in it so the rod end bearings were more parallel with the rudder horn and the tail wheel bracket. It works very well after 220 hours and 2.5 years.
Postby Bryan Cotton » Sun Dec 18, 2016 2:44 pm
I like the stock setup with the bushing idea. I'll try that and I can always upgrade later if I need to.
Postby tonyr » Sun Dec 18, 2016 7:42 pm
Is your pushrod fitted the wrong way 'round?
Sonex #813
First Flight... 4 Oct 14
298 hours having fun!
tonyr
Postby Area 51% » Sun Dec 18, 2016 9:24 pm
I got a very nice pneumatic tail wheel assembly from Peter Anson a while back. He also has available an offset steering rod, complete with heim joints. I plan on installing one of those on our Waiex when the time comes.
Area 51%
Postby Area 51% » Sun Dec 18, 2016 9:30 pm
So.........Kip..........How exactly do you keep track of your landings? I was thinking........maybe......a pedometer? I couldn't use one of those for landings without converting the count into dog-years.
Area 51%
Users browsing this forum: No registered users and 76 guests
