vwglenn wrote: Also, the impeller would not spin at the accident site it wasn't until the folks in D.C. messed with it that it started spinning...
kmacht wrote:I think this is the first post from someone at the factory saying more than they can't comment due to the investigation.
Sonerai13 wrote:This caused the compressor housing to contact the compressor wheel blades, which jammed the turbo...
There was no smoke system on the airplane.
There will be a final report that follows, which will include any "probable cause" statements that the NTSB wishes to make.
dc75 wrote:I didn't see anything about the integrity of the fuel system in the report, besides the aero injector flowed fuel when gas was added to the inlet.
The fuel tank had been separated and contained a residual amount of blue tinted fuel
consistent with 100LL.
The fuel tank was not relatively intact. The fuel filler cap was impact separated and the line from the bottom/rear of the tank was impact separated. The fuel level sensor probe remained attached to the tank; however the transmission wire was broken.
mike20sm wrote:I didn't see any mention of testing the magnetos. My thinking was that if you had two similar degradation of power incidents one on a turbo powered plane and the other on a standard non turbo engine and there seems to be no other problems with the engine rotating freely or the fuel was proven to be reaching the cylinders, then I'd suspect something in the ignition system. This is just me thinking out loud and I have practically no experience.
Users browsing this forum: Google Adsense [Bot] and 0 guests
