A company employee reported he experienced a degraded turbocharger system a few weeks prior to the engine functional test. During that flight, the airplane would fly level, but could not maintain a positive climb. He reported that after the flight, the turbo was examined and found to not be completely seized, but the piston ring-type seal on the shaft connecting the compressor and turbine wheels had partially seized and interfered with the shaft's ability to rotate. An examination of the accident turbocharger did not find a similar signature. Replicating a seized turbocharger during engine operation was not possible.
Fastcapy wrote:The turbo could not be rotated by hand. NTSB inspection shows little movement of the compressor blades in the housing at time of impact. There is a current SB regarding problems with turbos, yet you want to disagree that it may have been the turbo?
MichaelFarley56 wrote:Just asking to those who are smarter and I (pretty much all of you), is this the final report or will the NTSB follow with a "Probable Cause" statement?
