That rate of climb was SOLO, with cool outside air. Density altitude was 870', almost 300' below my field elevations! I flew two weeks ago for the first time at gross weight (close to 1150 lbs) and was seeing climb rates in the 300-400 FPM range with my son aboard.
Here's a few pictures from my recent flight to show you the numbers...
After leveling off I powered back to a speed cruise setting to see what the cold air would do for the performance...
