by MichaelFarley56 » Mon Nov 14, 2016 9:31 pm
Greetings Everyone,
I’m hoping to run a non-turbo AeroVee situation by all of you in hopes that, just maybe, someone has seen this issue before. To fill you in, I have recently rebuilt my AeroVee to be a normally aspirated (non-turbo) engine like it was when I first began flying my Waiex. I have everything rebuilt and the engine is running, but I’ve ran into a problem with engine tuning that I can’t figure out. To make a long story short, when I try to tune the engine I’m getting a major mixture split between the front two cylinders (closest to the prop) as compared to the back two cylinders (closest to the firewall) Left side vs. right side seems okay, and at idle everything seems to be okay but when I bring the throttle up and especially when I go to wide open throttle on the ground, the front two cylinders are running very rich while the back two cylinders are running incredibly lean. I’ve tried different AeroInjector needles and mixture settings but in this case, if I lean out the engine so the front two cylinders don't stumble from excessive richness, the back two cylinders have EGTs that spike to at or over 1450 degrees. On the other hand, if I richen the mixture so the back two aren't at or over redline, the front cylinders won't hardly run. Ultimately I'm seeing an EGT split between the front and rear cylinders of 300-400 degrees (1150 degrees on the front and 1450 on the back). Of course this also leads to the rear CHT’s to spike quickly while the front CHT’s stay very cool, further supporting the readings of the EGTs.
I didn't have this issue at all when the turbo was on the engine and nothing has really changed to the core of the engine since then. I've also checked the following:
- Valve lash was adjusted and then confirmed to be set properly.
- Heads all torqued properly
- Timing is set correctly
- Engine runs give same result with either ignition turned off (both ignitions were tried separately)
- Entire intake system has been gone over multiple times for induction leaks
- Intake elbows have been removed and re-sealed twice to check for leaks.
- Intake elbow spacers have been removed and re-sealed as well.
- EGT and CHT sensors have been swapped to check for readings reliability (all is reading properly)
- AeroInjector was overhauled at the factory and is properly installed.
- Multiple AeroInjector needles have been tested (#2, #2.5)
- Same readings are found with air filter on or off.
- A compression check shows similar readings on all cylinders.
- The heads are both brand new and only have 20 minutes of ground run check time.
At idle power of roughly 1000 rpm, I may see an EGT split of maybe 100 degrees (850-950 degrees) and the engine runs smoothly. As power is increased however, this front vs back split becomes larger and larger.
So, for those of you who are flying behind non-turbo AeroVee’s, I was hoping you’d be able to chime in and let me know if anyone else has seen this issue before and/of if anyone has any ideas on other things I can check.
While you’re at it, would anyone else be willing to share what your EGT split or range is when flying at full power such as takeoff? Is anyone else having issues with front cylinders vs back cylinders?
Thanks everyone!
Waiex #0056 - N569KM (sold)
Onex #245
