braking during run full run up
Postby Johns » Mon Nov 14, 2016 7:24 pm
Hi everyone, tried to do a full static run up to check rpms but my brakes would not hold. Just curios if anyone has had this problem and what did you do. I could tie the plane to the back of my truck. Am not going to do it in my tie down area while tied down in case something happened and I launched forward. Just wondering!!
John
Johns
Re: braking during run full run up
Postby nwawingman » Mon Nov 14, 2016 7:30 pm
This is normal. My Sonex standard brakes hold to 2500 rpm. You will need to tie down for full static ground run.
Rick Wantz - Arkansas
Sonex 367 T/W AeroVee/Aeroinjector - Prince Elliptical Prop <361hrs
1st Flight 7/13 KOSHX3 Young EaglesX14
http://www.mykitlog.com/wingman
https://www.youtube.com/channel/UC2TNLK ... A63FvnPkNA
nwawingman
Postby mike.smith » Mon Nov 14, 2016 9:25 pm
nwawingman wrote:This is normal. My Sonex standard brakes hold to 2500 rpm. You will need to tie down for full static ground run.
Pretty much the same for me. With the hydraulic brakes I get up to about 2,700rpm before is starts to scootch forward. For static tests you really need to tie it down. Much safer that way, too.
Postby wlarson861 » Mon Nov 14, 2016 11:44 pm
All my static runs have been with the tail wheel tied to a tie down anchor (set in the tarmac)brakes set and 2 x 4 wheel chocks. A friend used only wheel chocks and the gear walked over them.
Bill Larson
N861SX
wlarson861
Postby DCASonex » Tue Nov 15, 2016 9:40 am
My Great Plains hydraulic disk brakes will hold back my Sonex TD with CAMit 3300, -- BUT -- Couple of years ago running the Jabiru 3300, after conversion to solid lifters, was at end of runway that is on top of hill, and stray gust picked up the tail, despite holding full aft stick, and was looking down at runway. With a tail dragger, strong engine is trying to pull fuselage up over its gear, but with a runway light in front of me, could not just release the brakes and still not sure what kept it from going all the way over, but did bend tail spring when came back down. Now the only time I do full power runups is with tail tied.
DCASonex
Postby n982sx » Tue Nov 15, 2016 12:00 pm
I am surprised that peoples brakes aren't holding then back for full static RPM. I have the standard Sonex brake pads with the machined drums and they have always held to full static RPM.
Bob Meyers
Built and Flying Sonex N982SX http://n982sx.com
Built and Flying RV-14 N626KM http://n626km.com
n982sx
Postby Onex107 » Tue Nov 15, 2016 5:11 pm
I'm a Onex owner and I added a single foot brake pedal in front of and between the rudder pedals that is attached to the hand brake lever with a simple rod. I can hold a WOT run up with out a problem. The Onex has a busy left hand during that time and you don't want to have to hold a brake lever. It works great, I would do it again. I only use it during a run up.
If you want pictures you must email me at flyvfr@comcast.net.
OneX 107
N2107X
Onex107
Postby Johns » Tue Nov 15, 2016 6:51 pm
Thanks for the response guys. I have a lever for disc brakes on the control stick so the foot brake thingy wouldn't work for me . Thanks anyway. I'm going to tie my rear to an empty tie down area and go at it.
John
Johns
Postby daleandee » Tue Nov 15, 2016 8:17 pm
daleandee
Postby bakfly » Wed Nov 16, 2016 7:43 pm
n982sx wrote:I am surprised that peoples brakes aren't holding then back for full static RPM. I have the standard Sonex brake pads with the machined drums and they have always held to full static RPM.
I have the same machined drum breaks and do run up's at full static RPM and have no problems holding. I must say before the breaks where run in a bit the breaks could not hold fully at full static RPM but I could run up to at least 2500 RPM.
Peter,
Sonex 19-8464, Aerovee 2.1
Tri-gear. 138hrs.
bakfly
Users browsing this forum: Bing [Bot], tomwasser and 87 guests
