To trim the pushrods, I first did one by hand and considered it my "reference" pushrod. Next, I got a piece of 2X4 and drilled a couple 3/8" holes in it. The pushrods were a snug fit in the holes. On the left you can see I made a reference gauge out of scrap, so the new pushrod will always stick out of the 2X4 the same amount. This dimension can be anything, it just needs to be repeatable. Then I stuck my reference pushrod in, and squared up the ends with the ball.
Now over to the drill press. I adjusted the height of the table until the cutoff wheel just scraped on the reference pushrod.
And time to cut. The dremel wheel was not holding up so I had to find the big boy wheel.
I don't have a lathe.
And then a major setback- one of the lifters slipped out when we joined the case. We have to split it.
Crap.
