Area 51% wrote:Guess-timation is fine as long as one has some background or experience with a component in question. It is evident I wasn't clear enough in my statement that the published dimention was for a "STOCK" engine, and that it would be a "WORTHLESS VALUE" on a stroked engine such as the AeroVee. "I" wouldn't install the tubes without a given dimention, especially if it was my first build, any more than I would adjust the valves by "feel".
I'm still surprised there isn't a dimention to cover each possible incarnation of said AeroVee.
I still stand by my opinion that a published dimension for the pushrod tubes has little meaning. Too many variables. I've built an AeroVee 3 times and simply extending the bellows far enough to ensure compression when the heads go on, is all that has been needed. The dimension shown in Tom Wilson's book is 7-17/32 to 7-9/16"; a difference of 1/32"!! That's a laughable tolerance, especially since the bellows length WILL measure differently at every point around its circumference, simply because the bellows, being an accordion, will tip slightly one way or the other no matter how hard you try to keep it perpendicular to the pushrod tube body.
My suggestion is to worry about more important tolerances than the pushrod tube length, and simply extend the bellows so they require compression when the heads go on.
Tom's book also suggests you can add some Permatex to the seals before seating them in the case and the head. I don't believe that's part of the AeroVee assembly instructions, but from my experiences it's not a bad idea.
