by Bryan Cotton » Thu Oct 13, 2016 9:46 am
Kevin,
You are right that the skins hold the wing square. The root rib is not parallel to the other ribs (classic A model). If you drill the root rib to the angles when the wing is not square, you will have to flex the root rib to get it to line up later.
