by wlarson861 » Tue Oct 11, 2016 12:08 am
This is the same symptoms I had only I would get 35 in. map at full throttle. When i took off the tailpipe I could freely turn the turbine but I suspect it was not as free as it should have been. When I test ran the engine after replacing the heads I could only get 2500 to 2700 rpm static. When I removed the turbo to send to Sonex, the turbine was seized completely. Sonex's turbo supplier said the shaft was seized due to coking of the oil in the bearing and found scoring in the bearings from metal in the oil. I'm afraid your symptoms are a harbinger of doom seen by the other three turbos that have had problems. I, unfortunately did not check the turbo when new to see just how freely the turbine would spin, when checking it in May it turned freely but I suspect it was coking up but just hadn't seized although it was dragging the turbine down for the reduced map.
Bill Larson
N861SX
