radfordc wrote:Mine is like option A. The master switch must be On in order for the ignition to work. The concern of course is that if you have a master solenoid failure the electronic ignition will not work. I consider the electronic ignition a "backup system" and often fly with it shut off.
onex28 wrote:He reinstalled the engine and it will run on the magnatonsnbut shutsdown when he switches to the secondary ignition. He is quite frustrated. Any sggestions? Thanks
Users browsing this forum: Google [Bot] and 40 guests
