by dbdevkc » Sun Oct 02, 2016 10:03 am
First off you may not be a scratch builder, but you are still a builder. There are many such hurtles you will need to devise a solution for along the way, and often times there is no one correct way to accomplish a task.
In this case I don't have a ton of experience, and this idea seemed to just pop into my head, so I may have seen it on another builder's website build log, I don't know. There does seem to always be a "better" way of doing something. Sometimes it is worth any extra time that may take, sometimes not. When you are struggling to do some task and it is becoming a problem, it is time to try a different way.
Regarding the aft ribs, if you just lay the gussets on the 'outside' of the ribs, can you get the holes to line up at all? NOTE: For the aft ribs, the upper and lower gussets look VERY similar in size and shape (but they are slightly different - lay one up against the other and you will see the difference), and even the holes at first glance look like they are in the same place. But they are not. Make sure you are using the top gussets for the top, etc. That would make sense why you found some of the holes to be off.
Just keep going. Carefully check each part before you do any bends, drill any holes, etc. Don't be afraid to ask dumb questions. Looking at other builder's website build logs helps too.
Kevin
[color=#800000]Kevin Conklin
Building Waiex #169
