Bryan Cotton wrote:I could use a recommendation for a valve compressor tool for the VW- anybody?
Next we went to bolt the cam gear to the cam. My cam kit had 3 bolts and two wavy washers. Where is the best place to get one? Any VW afficionados have a spare they could mail me?
Well, onto the rods. Opened up my lithium grease to find it is black, not white as called for. Darn! Any reason I can't use the moly engine assembly lube I bought? Reading the label it seems like this is what it is for.
You should be able to get the wavy washer just about anywhere It's just a thin M8(Lowes, Home Depot, Local auto parts, in the Metric section). I'm sure I have a bunch of wavy washers floating around in my garage somewhere.Don't forget to use some thread locker on those cam bolts. Ask me how I know. :roll:
I have an old valve compression tool for VW heads. Think I've used it once. It's steel and pretty big but I'd be happy to ship it if you'd like. Looks like this but it's probably 50 years old...
I don't see why you couldn't use the assembly lube of your choice but I've never actually read the Aerovee assembly manual. Think the last engine I put together I used a friends stuff and it was purple. Turned the engine oil pinkish when we broke the engine in and drained the oil the first time.
