by Lsaircraft » Tue Sep 27, 2016 9:50 pm
Hey guys getting ready to mount my Sp-3HC for the MGL I have the lead under it and foam around it, I see it says center of rotation OK that's not an issue but does it need to be centered in the Aircraft (side to side)? not sure I can do that, Installing in a Kitfox, I am asking you guys because I see Sonex airplanes with this same setup, Thanks TJay Larsen
Lsaircraft
by Fastcapy » Tue Sep 27, 2016 11:14 pm
I would mount it as close to practical to the aircraft centerline.
Mike Beck
Oshkosh, WI (KOSH)
Sonex #1145 N920MB
Fastcapy
