by surfly » Mon Sep 26, 2016 1:11 pm
Upon motoring my new built engine with the starter, no prop, or spark plugs inserted, my oil pressure immediately rose to 80 psi and then dropped to 0 psi while still motoring. Tried three times with the same result. No exterior oil leaks noted.Could this indicate that I have one of those case halves that had bad machine work resulting in open oil pressure galleys. If this is indicative of a bad case half I would like to know now before I proceed any further.
Sherm
