Oil pressure drop, bad case half??????
Postby surfly » Mon Sep 26, 2016 1:11 pm
Upon motoring my new built engine with the starter, no prop, or spark plugs inserted, my oil pressure immediately rose to 80 psi and then dropped to 0 psi while still motoring. Tried three times with the same result. No exterior oil leaks noted.Could this indicate that I have one of those case halves that had bad machine work resulting in open oil pressure galleys. If this is indicative of a bad case half I would like to know now before I proceed any further.
Sherm
surfly
Re: Oil pressure drop, bad case half??????
Postby Bryan Cotton » Mon Sep 26, 2016 1:40 pm
Bummer Sherm. I am about to start my build and will inspect the case carefully. The SB does list the procedure, and suspected date range.
http://www.aeroconversions.com/support/aerovee_sb.html
For an assembled engine you need to pull a head and one cylinder. Good luck!
Postby Sonex1517 » Mon Sep 26, 2016 7:20 pm
Sherm
Just my two cents, but are you sure the oil pump is still primed? I had to prime it again after the first spin to get oil pressure to stay up.
Robbie
Aero Estates (T25)
First flight 10/10/2015
375+ hours
Jabiru 3300 Gen 4
Prince P Tip
Taildragger
N1517S
Sonex1517
Postby kmacht » Mon Sep 26, 2016 11:52 pm
Are you sure the gage or sensor didn't go bad? I had the oil pressure sensor fail on my aerovee during ground running testing. Check it with a manual gage before tearing the engine enables back down. I also second the suggestion to reprime.
#554
kmacht
Postby wlarson861 » Tue Sep 27, 2016 1:05 am
I only use my manual gauge. I'm on my 3rd electronic and they have all been inaccurate. Put in a manual that only cost under $30,be assured you have the right oil pressure
Bill Larson
N861SX
wlarson861
Users browsing this forum: Bing [Bot], tomwasser and 95 guests
