jwd3ca wrote:this is a Transpo/Kohler regulator KH4309 typically used on John Deere mowers, marine engines and several motorcycles (Ducati, among others). It is exactly the same regulator available online ( http://goo.gl/E0vyVU )
jwd3ca wrote:looks that way based on what? The regulator that you have on your AeroVee? How does it differ?
jwd3ca wrote:As I said, the Sonex wiring diagram shows that one AC tab is tied to B+. So I guess you could say that Sonex does say otherwise...
jwd3ca wrote:So, assuming that the tied tabs are required (prolly for voltage sensing), what's the best way to tie them. My first thought was a copper strip soldered to the two tabs, but I'm worried the heat required may be problematic. The other option is via wiring. Just wondering how those who have done it (successfully!) have done it. Thanks.
jwd3ca wrote:Maybe my originally-not-bridged-but-bridged-by-me reg. will work fine w/o the tied tabs! Either that or I ruined it by following the wiring diagram :(
