by mike.smith » Sat Aug 20, 2016 8:47 am
1. Make sure you install the RIGHT wing first!
2. I kept notes from other builders during my build. I don't know who to attribute these notes to. Maybe they will help, maybe not.
It is much better to rig the wings without the ailerons and flaps installed.
The best advice I could give is to have at least two other people assist you as you will need six hands to hold tape measures and jostle the wings to get everything to fit and make measurements. Naturally, it is best if these others have already rigged the wings on their Sonexes!!
Expect to need to trim the forward fuselage holes where the spars "slide" into the spar tunnel. I think mine needed trimming on the top and bottom of both sides. Be prepared with tools on hand such as laser levels and standard levels, tools or materials to turn into shims to properly place the rear spars into the fuselage and for me a high torque drill was quite necessary as the holes for the main spars are long. To shim the rear spars, I had wood wedges on hand but as it turned out hand files worked into position did the trick.
Otherwise, review the builder's web pages on the Sonex site and budget five or so hours and all will go well!!
