sonex892. wrote:Hi Rick
Sorry, I don't know of a better way. I just used what the engine came with, 1/4" rubber fuel line. I covered the hose with fire sleeve from gascolator to mechanical pump to carb. All other fuel lines I used 3/8" aluminium tube with AN6 hardware.
Using non matching hardware like 3/8" rubber tube on the 1/4" or 6 mm fittings, Could be quite dangerous.
Steve
Sonex 892
3300 215hrs
Found that even the mismatch of 1/4" ID hose on that 6 mm barb into fuel pump can be problematic. (The output barb is 1/4") Would sometime suck a tiny bit of air at that fitting which would tend to vapor lock the pump. Now have that connection double clamped with the type of clamp used on higher pressure injection system, not worm gear type which tend to bunch the hose in one location. Entire system on engine side of firewall is 1/4" rubber fuel line with fire-sleeve, except for the long run of aluminum tube into the red cube, and that is also in fire-sleeve. (Also have cool air blast tube on the engine driven fuel pump that made a very big improvement on stability of fuel pressure.)
David A. Sonex TD with CAMit 3300
