by N111YX » Tue Jun 19, 2012 10:27 pm
I have flown one aircraft that exhibited negative longitudinal stability and that was a Titan Tornado II. When the pitch was changed (be it pilot or turbulence) the nose would accelerate to the displaced direction. Talk about a labor-intensive cross country machine... :? Attempting to unfold a chart could cause the pilot to float out of his seat or a pitch up to aerobatic attitudes in a matter of seconds. On the same note, the Challenger II design is bad in directional stability. If it yaws, it stays crooked! The worst flying fixed wing that I have flow is a Mitchell Wing A-10. Conventional inputs into the 3-Axis machine brought about unconventional results. That and the owner killed himself in it two weeks later... :cry:
The Sonex handling is in a league way above many designs in my opinion...
Kip
Jabiru 3300 #1637 and #3035
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1175 hours
48 states visited
Based near Atlanta
Also flying a...
