by Sonex1243 » Sun Jul 31, 2016 3:08 pm
Bryan,
Went back to square one and verified longeron and vertical placement, the #1 vertical has the same 1/32" difference both sides, but this was back from being flush with the forward edge of the skin? I wonder if this is due to the longerons themselves as they all had a little twist / bow in them when laid flat on the skin. One had so much that I had to clamp it down on the table edges in sections and remove the twist by applying a lot of opposite twist with a crescent wrench! Once reassembled, everything is right at 1/32" from dimensions called out on the plans for both sides.
I bit the bullet and inquired with Sonex Tech, I have all the confidence in the world that the whole match hole concept is to allow a person to cleco parts, upsize and rivet as you go, eliminating the countless hours of laying out and piloting assemblies together.
Going to go tow gliders!
Ken S
SONEX #1243 N424SX (reserved)
Tail complete, wings done
Fuselage on gear
Jab 3300 received!
