peter anson wrote:Hi Rob, I don't think any of us are qualified to say whether the part is OK or not, and even if you contact Sonex I think they will just say that the part must be made to the plans. It even depends on where the gouge is - near the bend at the root is bad. Most people make these using just a drill, file and band-saw. Drill a hole to get a neat radius, band-saw up to the hole and then file the edges. It's surprisingly quick to do. A small sanding drum in a drill will tidy up the edges and radii nicely and get all the scratches going in the right direction. If you do decide to make another part, you haven't lost out completely. You can use the first ones to try out the bend.
Sonex 894
Yes, it was scratch built
Users browsing this forum: No registered users and 34 guests
