1X99 wrote:I'd be test flying my Onex now except the static in the radio reception makes it a little scary. Engine off, the radio (Garmin GTR 200) receives clear as a bell. Start it up, and static makes communication really dicey. I tried disconnecting the stator; no change. I borrowed a hand held radio; same result. My guru suggested using shielded wires throughout the secondary ignition system. Magnetrons already connected with shielded P leads. I've tried it using the individual ignition systems; about the same with either.
Has anyone had a problem like this? Solutions?
I'm working on the suggested fix; will report any improvement.
Steve Craigle TurboOnex 099
mike.smith wrote:1X99 wrote:I'd be test flying my Onex now except the static in the radio reception makes it a little scary. Engine off, the radio (Garmin GTR 200) receives clear as a bell. Start it up, and static makes communication really dicey. I tried disconnecting the stator; no change. I borrowed a hand held radio; same result. My guru suggested using shielded wires throughout the secondary ignition system. Magnetrons already connected with shielded P leads. I've tried it using the individual ignition systems; about the same with either.
Are you sure it's static? The Sonex cockpit can be quite noisy, so I have to turn my MIC gain down quite a bit or the ambient noise comes in the microphone and makes everything sound scratchy, or like static. What does your radio sound like to radios outside your plane, when you are transmitting?
Glenn.hunt wrote:He said he blocked the surface area on the mic (both sides) by 50% and it made a big difference for him by not picking up so much ambient cockpit noise.
