by Sonerai13 » Thu Jun 30, 2016 8:59 am
Always check YOUR aircraft's operating limitations, that were issued by the FAA as a part of its airworthiness certificate, for specific info on how to close out the flight test period. These operating limitations are supposed to be uniform, but I've seen some that are not exactly as the FAA Order spells out. Regardless of what the order says, or what your operating limitations are supposed to say, the controlling factor is what your operating limitations actually DO say.
Your FAA inspector or DAR was supposed to go over your operating limitations document in detail with you when they certificated the aircraft. If they didn't, bad on them. But it's still the operator's responsibility to adhere to what the operating limitations say.
AND, make sure the operating limitations are IN the aircraft during each flight. They are a part of the airworthiness certificate, and as such must be in the aircraft. The day you leave them laying on the workbench and go flying is the day you'll get ramp checked!
Joe Norris
Sonex N208GD (S/N 450)
Sonerai II N13NN (S/N 1206)
Fortes Fortuna Adiuvat
