marlinz wrote:Is it normal to have some soot build up in the intake ports? Would that be a result from not having the valves set right? The engine has about 60 hrs on it, and the clearance gets less between adjustments or doesn't have any clearance at all. That would keep the valves from closing all the way.
Mine needed adjustment at every check also--to the point I ended up having to make shorter pushrods. Does the torque on the head nuts also need frequent adjustment? I've wondered if the frequent adjustment is due to the copper head gaskets crushing. When I rebuilt my engine (with new copper gaskets) I was very careful with the torques and re-checked them a few days in a row while it was in my workshop. Anecdotally, the second build seems to have more stable clearances, but there's always the possibility that the engine had already "stabilized" by that point.
I've had both heads off and checked for valve leaks with alcohol and re-lapped 3-4 valves. Like you, I'm curious if the "soot" build up on the valve seats causes the leak or is a symptom. I'm a little suspicious whether the lead in the fuel causes the problem. I'm also curious to hear if anyone carefully lapped their valves before they first flew their engine and how long they had good compression for.
As far as the cracks between the valve seats, I've decided to keep tabs on them and will become concerned if I see them extend below the valve seats (I am unaware of any Aerovee owners who have seen the crack extend to that point). This opinion of mine is largely due to noticing that other similar heads simply have a gap between the seats in this area.
