Other than Sonex Pics.
For non Aviation related discussions.
Re: Other than Sonex Pics.
Postby N111YX » Wed Jan 25, 2012 3:39 pm
Of course, I have given thought to it. It's my understanding that EXPERIMENTALS are not allowed east of Bahamian airspace...so far... 8-)
MichaelFarley56 wrote:Great pics Kip! Have you started planning the route you'll take when you fly the Waiex down there? ;)
Kip
Jabiru 3300 #1637 and #3035
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1175 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Postby rizzz » Wed Jan 25, 2012 7:14 pm
BTW, if you have not seen this yet, this website has some awsome aviation pics & videos:
http://www.crazyaviation.com/english.htm
Postby N111YX » Tue May 22, 2012 5:04 pm
Pitts fuselage arrived today. 435 lb crate for a 52.5 lb fuselage (there were a few other parts and a set of plans thrown in).
Makes a great conversation piece!
Kip
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1175 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Postby falvarez » Tue May 22, 2012 5:59 pm
And I thought I had workspace issues :D Looks like a fun project.
Frank Alvarez
Sonex #800, Aerovee 2.1
falvarez
Postby MichaelFarley56 » Tue May 22, 2012 8:58 pm
Awesome! Looks brand new!
Postby N111YX » Tue May 22, 2012 9:58 pm
I've found that the biggest difference from the Waiex build so far is the lack of a hardware kit. With the Waiex, I could read the plans and reasonably expect to go and find whatever nut or bolt and continue on. The Pitts plans have all of callouts on the plans page but think about it...imagine scouring the Sonex plans pages for the hardware that you'll need then placing and order. How far to you look into future pages? (!)
Good thing Aircraft Spruce is only a 45 minute drive away... :)
Kip
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1175 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Some Pitts Pics
Postby N111YX » Mon May 06, 2013 9:37 pm
Your looking at about 450 hours of work on the wings. I did not weld the fuselage. It's a Pitts S-1D. Quite rare in that it has a flat bottom wing with four ailerons. Most Pitts' have a symmetrical airfoil except for the early ones but they usually had only two ailerons... :P
Upper wings in the living room.
Upper left wing trailing edge.
Kip
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1175 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Postby N111YX » Mon May 06, 2013 9:38 pm
Part II
Lower right wing.
Lower right wing fuselage attatch point.
Drag wire installation (above the spar centerline to clear opposite crossing wire).
Kip
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1175 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Postby N111YX » Mon May 06, 2013 9:40 pm
Part III
"Trammel" point used to keep wing bays square.
Strong point on the spar where the flying wires will attatch.
Drag wire drilled throught the spar.
Kip
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1175 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Postby falvarez » Mon May 06, 2013 9:57 pm
Looks great Kip...can't wait to see the finished product. How do you like the woodwork....I didn't realize there was so much of it on that plane. I thought scratch building a Sonex took patience, but I think you must have way more than from the looks of all that intricate woodwork.
Frank Alvarez
falvarez
Return to Off Topic
