Source For 3/8 OD 1/4 ID Steel Tubing
Postby Direct C51 » Fri Jun 24, 2016 1:10 pm
I attached my spars and drilled my wing attach blocks to final size before assembling the wings. My intention is to use a 3/8" OD steel tube through the attach blocks as a drill guide to drill a 1/4" pilot hole in the wing attach angles, and then use a piloted bit to drill them to final size. I am now ready to attach the wings, and am having trouble sourcing a 3/8" OD 1/4" ID steel tubing. Any ideas?
Nate
Direct C51
Re: Source For 3/8 OD 1/4 ID Steel Tubing
Postby Bryan Cotton » Fri Jun 24, 2016 1:30 pm
Nate,
I got mine from A/C Spruce - BUT the OD was exactly 3/8" so it did not fit in the holes I reamed to .3725 to fit my AN6 bolts nicely. Also the ID was a little smaller than 1/4". I called in a favor with a friend with a lathe. When I am done I will make mine available to the community but that is a few weeks away.
Postby Direct C51 » Fri Jun 24, 2016 1:34 pm
Bryan, that sounds like it will work nicely. If I can't find a source for the tubing by the time you are done with it, I would certainly like to be first on the list to use it. I'll pay for shipping of course.
Nate
Direct C51
Postby Sonex1517 » Fri Jun 24, 2016 4:37 pm
McMaster Carr has what you need. I bought some there to do my wing rigging.
Postby Direct C51 » Fri Jun 24, 2016 5:56 pm
Robbie, do you have a part number? All I can find is .245" or .277" ID. I think .245 would be too small to allow a 1/4" bit to enter, and .277" too big and allow the 1/4" bit to wander around.
Direct C51
Postby Bryan Cotton » Fri Jun 24, 2016 6:26 pm
Did you see my nifty trick for updrilling tubing without a lathe? In the middle of page 76:
viewtopic.php?f=39&t=578&start=750
Postby sonex892. » Fri Jun 24, 2016 8:35 pm
I got mine from spruce. Had to remove a tiny bit off the OD with emery cloth whilst spinning it in the drill press. I had to run a 1/4" bit through the ID. A lathe would be nice but not necessary.
http://www.aircraftspruce.com/catalog/m ... ushing.php
Wicks also sell it
http://aircraftproducts.wicksaircraft.c ... bs3-8-1015
Steve
Sonex 892
Steve
Lazair kit 1981 sold
Sonex kit 2010
Sonerai 2LS project rotax 912
sonex892.
Postby Sonex1517 » Fri Jun 24, 2016 9:42 pm
Direct C51 wrote:Robbie, do you have a part number? All I can find is .245" or .277" ID. I think .245 would be too small to allow a 1/4" bit to enter, and .277" too big and allow the 1/4" bit to wander around.
Apologies. I do not.
Users browsing this forum: No registered users and 48 guests
