by SonexN76ET » Wed Jun 21, 2017 9:57 am
Is this a new installation or have you been flying awhile and just encountered this situation?
You mentioned a cold air intake for the AeroInjector. One thing about the AeroInjector is it does not do well with pressurized air or ram air as that changes the fuel air mixture which the AeroInjector can not automatically adjust to.
Have you insulated your fuel lines and kept them away from the exhaust pipes?
Have you done a fuel flow test?
Have you checked the mixture settings as exactly specified in the AeroInjector manual? The AeroInjector is extremely sensitive to improper mixture needle settings.
I would check to make sure you are not running too rich as an initial check.
Please do not fly until you get this solved. Take it one step at a time. Do not try two "fixes" at the same time. You will have this figured out in no time.
Please do not hesitate to contact AeroConversions for help with the AeroInjector.
Please keep us updated on your findings and feel free to ask more questions.
Jake
Sarasota, Florida
