Static Port Location
Postby 8pointroll » Thu Jun 16, 2016 5:20 pm
Looking for some input on the best location for a static port on a tri gear Sonex. Thanks for your help. Stuart s/n 1106 most everything done but the wiring.
8pointroll
Re: Static Port Location
Postby fastj22 » Thu Jun 16, 2016 8:07 pm
8pointroll wrote:Looking for some input on the best location for a static port on a tri gear Sonex. Thanks for your help. Stuart s/n 1106 most everything done but the wiring.
Mine is per the plans, right under the pitot tube.
Postby ScottM-Sonex1629 » Thu Jun 16, 2016 8:34 pm
Same here, per the plans. Used he aircraft spruce supplied pitot static unit. Far as I can tell works great after 3 flights.
Scott Meyer
Sonex 1629 - Sold...9/2019
ScottM-Sonex1629
Postby gammaxy » Fri Jun 17, 2016 11:06 am
From my experience, it seems likely that someone could find a better location for the static port, but the plans location seems to work fine in the situations that most of us actually care about.
I'm unaware of anyone installing it somewhere other than the plans location.
It seems that locating it below the wing causes it to be influenced by the wing. The clearest way to demonstrate this is by pulling a couple G's from level flight while watching the altimeter--it's not hard to make the altimeter drop a hundred feet or so even though it is obvious you are accelerating upwards. If you have telemetry and you compare GPS altitude and the altimeter during the flare when landing, you'll see that the altimeter might drop 20 feet during the flare and then return to the correct altitude while slowing down on the runway. The other thing I've noticed is it seems the indicated airspeed of a stall is approximately the same in a 2G accelerated stall as a 1G stall (instead of ~40% more). I haven't really investigated all the details, but to me it seems that the airspeed indicator with the static port below the wing functions similarly to a lift reserve indicator.
The opposite of this is also true--unload a little on the stick in a climb and watch the vertical speed indicator increase by 100-200 fpm.
All of these examples are probably situations where you won't be paying much attention to the altimeter anyway. I've never noticed an error during cruise flight--at lower angles of attack the static port is less influenced by the wing.
Users browsing this forum: No registered users and 105 guests
