by Mike53 » Wed May 16, 2012 5:17 pm
Hi fellow Onex builders.
Has anyone had any issues with lining up all the holes around the rear fuselage
vertical assembly F20-02 ?
For me I can cleko the sides,and the top but the 2 holes in the lower mount
angle are off.
That is they do not line up with the matching holes on the lower longerons.They
are off by about an 1/8".
I can force them to fit but only by using a clamp and pulling it in line ,but it
is obvious the cleko's are being strained on the side closest to the bottom.
Kerry so far has no answer why ,he has passed it on to Jeremy and he is at a
loss also.
If anyone has had to force them I would like to hear from you .
Thanks'
Mike
Mike
Antoine de Saint-Exupery
