Locktite 272 substitute
Postby n502pd » Wed Jun 08, 2016 1:54 pm
I am having trouble finding # 272 for the gland nut used at the flywheel. Has anyone used anything else with great results? I do have #271. :?:
Joe Nelsen
scratch built :D
Flying @81.7
KGYI/N. Tx Reg/Perrin Field
n502pd
Re: Locktite 272 substitute
Postby kmacht » Wed Jun 08, 2016 8:54 pm
You can get it on amazon for about $30. I think that Permatex bought out locktite. They have an equivalent but I'm not sure what it is off the top of my head.
#554
kmacht
Postby n502pd » Thu Jun 09, 2016 11:29 pm
Thanks much Joe! I did find the technical spect of Permatex red #27200 thread locker. It is exactly the same as Locktite 272, both being 450 deg and for items up to 1.5 inches. I should be good to go! and thanks to all the others for info too!
Joe Nelsen
scratch built :D
Flying @81.7
n502pd
Postby Sonerai13 » Fri Jun 10, 2016 8:49 am
n502pd wrote:I did find the technical spect of Permatex red #27200 thread locker.
Take note of the part numbers of the Permatex thread locker products. They are the old Loctite numbers, followed by a number symbolizing the size of the container you're purchasing! So if you see a Permatex thread locker bottle with a part number that starts "272xx" you're getting the old Loctite 272. Same goes for all the other Loctite numbers. Easy peasy!!
Joe Norris
Sonex N208GD (S/N 450)
Sonerai II N13NN (S/N 1206)
Fortes Fortuna Adiuvat
Sonerai13
Users browsing this forum: Google [Bot] and 72 guests
