mike.smith wrote:- Ever since then I usually average about 4.5 gph. So to me, 4.09 gph is too lean and may be part of my heat problems. It can't hurt to check so I'll richen the mixture a bit and do some tests.
gammaxy wrote:Your speeds and climb performance seem to indicate you are getting about 80% as much power as I am. Have you checked recently that the throttle is free to open completely? Is it possible for there to be some slop or stretch in the system so that when the engine is running the throttle hits a different stop before opening completely? Ever experimented with a less-restrictive air filter?
What compression ratio and combination of shims did you use when rebuilding the engine?
I'm really hoping you figure this out soon.
radfordc wrote:mike.smith wrote:- Ever since then I usually average about 4.5 gph. So to me, 4.09 gph is too lean and may be part of my heat problems. It can't hurt to check so I'll richen the mixture a bit and do some tests.
The very least fuel burn I ever saw was over 4.75 gal/hr in cruise flight at altitude with the mixture leaned severely. Making power I always saw over 5 gal/hr.
Users browsing this forum: Google [Bot] and 70 guests
