by mike.smith » Sun Jun 05, 2016 8:28 pm
I used to have the ground adjustable prop. Now I have the recommended 54" Sensenich. With both props my climb performance has been anemic and quite scary, especially at gross weight. I don't know if there is anything anyone can suggest but let me tell you what kind of numbers I'm seeing and perhaps you will think of something.
I've rebuilt the engine a couple of times (replace Nickasil cylinders with cast iron, and after replacing the crank and bearings from a prop strike). All 3 versions of the engine have run with the same numbers. While always seeming to under perform a bit compared to some other AeroVees, the numbers appear to be within specs, so I think I've built the engine well and haven't done anything to compromise performance. I have the wheel pants and gear leg fairings (tail dragger) installed.
My #1 cylinder always runs hotter than the others. EGTs often run about 100 deg higher than the others (even #3). CHT also run hotter, often around 50 degrees. This has been true in all three engine builds. I have installed a metal deflector in the cowl opening to deflect some air away from #2 and back to #3 but that has not seemed to do much if anything. My cowl seals are all tight and the super tin and baffles are in good shape and installed where they are supposed to be.
The #1 and #3 cylinders have always run leaner than the front two, which is easy to see when you look at the insides of the heads and at the spark plugs.
During run-up, turning off the secondary ignition yields an rpm change of 0-20 rpm. In flight if I turn off the secondary ignition I don't see any measurable change in temperatures.
After the winter I richened my mixture. During my last flight the engine was running a bit hot, and the #1 cylinder is what dictated how I climbed and how I adjusted the mixture. Since it was running hot I kept the mixture close to full rich most of the time. When I got back home and put gas in the tank I had burned 9 gallons for 2.2 hours of flight, so my fuel flow was 4.09 gph. So I think I'm still running too lean. I'm going to richen the mixture another 1/8 turn and see what happens. But if I run full rich on takeoff I often get an rpm drop, so leaning the mixture at least a little seems to give the best rpms.
There were times on this last flight where the #1 EGT was at 1380+ but the CHT was at 365. I usually see 390+ on the CHT if the EGT is correspondingly high. So I'm not sure what to make of that. But it wasn't consistent like that.
The climb with the prop is still pretty anemic. I now tend to get off the ground, build up speed in level flight, then pull back the stick and climb past the 60' trees at the end of a 2,700' paved runway (at 270' MSL). I've altered my first fuel stop on the way to OSH this year so that I won't be taking off toward Pennsylvania mountains like last year (and scared the crap out of me!). I have been keeping track of my performance numbers. On my last flight:
Climb out = 3,150 rpm at about 200-250 fpm
- Weight 961 lbs (Plane 655 lbs, me 190 lbs, full fuel 102 lbs, smoke oil 3 lbs, tool bag 11 lbs)
Climb to altitude:
3,030 rpm, 250 fpm, 72 kts, 68 deg OAT (took me 20 miles and 20 minutes to climb to 5,500')
Cruise 1:
3,130 rpm, 5,500', 93 kts indicated, 63 deg OAT (if I bumped up the rpms my #1 cylinder temps went up, but if I richen the mixture maybe I can bump a little more out of the rpm and airspeed, but 93-96 kts is about all I can get right now. With my old prop I was at 105-107 kts but the climb was just as bad.)
Cruise 2:
3,160 rpm, 5,500', 96 kts indicated, 57 deg OAT
Maximum RPMs in level flight, if I ignore the high EGT/CHT numbers, is about 3,250 rpm.
Another AeroVee owner noted:
I see around 600 to 700 fpm when flying solo with full fuel at around 80mph on climbout. I don't have the tool bag or smoke oil but am at 667lbs empty so it should be about the same.
So I don't know what might be up, but flying at gross weight is downright scary, as there is very little climb performance. Often I see 3,150 rpm and 100-150 fpm, and my #1 and #3 cylinders are all bumping up into the red.
Any insights would be appreciated.
Mike
