I'm really surprised this hasn't been done yet. Using Sonexoldmans 7.5" I did 3 profile sketches to see what the sonex might look like with a longer nose.
Having built a Sonerai with a 2200 Jabiru. I moved the engine forward for all the same C of G reasons. I found out moving engines forward can also drastically change the look of an aircraft. The long nose Sonex doesn't appear look that different compared to the original as my Sonerai did.
Top : Standard Sonex
Middle: modify cowl and engine mount only
Bottom: Raise windscreen/canopy bow approx 18mm, raise upper firewall approx 35mm, modify cowl and engine mount.
