Ken's Sonex 1243
Re: Ken's Sonex 1243
Postby Sonex1243 » Wed May 11, 2016 9:46 pm
Slow progress. Fit and pilot drilled the right wing tip. Was a little rough and I too, will need to play with fiberglass to fix a few dings.
Laid out the leading edge cutout for the right wing light
The big scary cut, measured over and over, just need to cut it out!
Ken S
SONEX #1243 N424SX (reserved)
Tail complete, wings done
Fuselage on gear
Jab 3300 received!
Sonex1243
Postby Sonex1243 » Fri May 13, 2016 9:53 pm
Scary cut done! Time for filing etc...
Ken S
Fuselage on gear
Jab 3300 received!
Sonex1243
Postby Sonex1243 » Wed May 18, 2016 10:45 pm
Slowly picking away at the lens install for the right wing. Cleaned up the edges of the cutout and fabricated the lens retainers. Riveted in the upper retainer and have the lens all prepped for marking and trimming. Will get it done eventually..
Ken S
Fuselage on gear
Jab 3300 received!
Sonex1243
Postby Bryan Cotton » Thu May 19, 2016 6:54 am
Hey Ken,
I recognize those parts. I see you went with nutplates also. Looks great!
Postby Sonex1243 » Fri May 27, 2016 8:46 pm
Did you do the duckworks lights Bryan?
Finished the right wing landing light lens today. Also finished riveting the ailerons, decided to install the tips and mask and paint later.Will up-size the wing tip once I get the tip light mount pods fitting right.
Starting the left wing landing light and wing tip after the holidays, off to the cabin!
Ken S
Fuselage on gear
Jab 3300 received!
Sonex1243
Postby Bryan Cotton » Fri May 27, 2016 8:56 pm
Ken,
I did not. I have the Fresh Aero lights:
http://www.freshaero.com/tlrlight.html
The parts look similar. I do like the Fresh Aero kit.
Your progress looks great!
Postby Sonex1243 » Sat May 28, 2016 7:38 am
Bryan, those fresh aero's look really nice, the retainers do look alike. Once the left wing is finished, it's on to the aft fuselage.
Ken S
Fuselage on gear
Jab 3300 received!
Sonex1243
Postby Darick » Wed Jun 01, 2016 8:42 am
Ken, nice job on the lights!
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
Darick
Postby Sonex1243 » Sat Jun 04, 2016 9:19 pm
Thanks Darick!
Left wing landing light install progressing slowly. Leading edge cut out and upper lens retainer fabricated and installed. Just need to flip the wing over for the lower retainer and lens install.
Ken S
Fuselage on gear
Jab 3300 received!
Sonex1243
Postby Sonex1243 » Mon Jun 06, 2016 9:12 pm
Finished the left wing light lens install last night and fit the wing tip tonight. As far as I can go on the wings for now, will install the aileron weights after I get the bolts swapped out for countersunk screws since there is a slight rub on the rib with the AN bolts. Once I get the gauge pod and pulsar EXP light fit better, will upsize and install the tips.
Ken S
Fuselage on gear
Jab 3300 received!
Sonex1243
Return to Photo Album
