Oil cooler cowl inlet
Postby onex28 » Tue May 24, 2016 3:25 pm
For you builders completed and flying behind the Aerovee what is the optimum size cowl inlet opening for the oil cooler. I'm looking at something around 5 X 1 1/2 inches but don't know if that is too small, too large of about right.
David W
onex28
Re: Oil cooler cowl inlet
Postby Sonex1517 » Tue May 24, 2016 3:45 pm
Turbo or non turbo?
Top mount or bottom mount oil cooler?
When I made my Sonex cowling I built it per plans, but had a turbo with a top mounted oil cooler. I ended up taping over the oil cooler inlet for cooling purposes.
So the answer may depend on your configuration.
Postby onex28 » Tue May 24, 2016 9:49 pm
Robbie, it is a non turbo and bottom mounted cooler. Thanks.
David W
onex28
Postby wlarson861 » Wed May 25, 2016 12:50 am
I used the dimensions called for in the plans when I first built the airplane with the bottom mount cooler and found it to be effective at cooling the oil. When flying below freezing temps it was too effective and fashioned a grill to cover the opening to cut down the amount of air and raise the oil temp some. If still building, I would go with the plans dimensions and see how well it works, understanding that a brand new engine will be hotter at first until well broken in. After moving to the turbo and top mount oil cooler I left the lower intake open to pass cooling air across the oil pan. The top mount was a bit cooler when normally aspirated but not drastically so. Turbo charged, the oil temps went up a little. Recently, with oat at altitude around 60 to 70 F the oil temps have been about 170 F. Well below the high limit.
Bill Larson
N861SX
wlarson861
Postby kevinh » Wed May 25, 2016 11:28 am
wlarson861 wrote: After moving to the turbo and top mount oil cooler I left the lower intake open to pass cooling air across the oil pan. The top mount was a bit cooler when normally aspirated but not drastically so. Turbo charged, the oil temps went up a little.
This may be off-base (because I haven't even finished my Waiex). But have you considered an experiment of taping up the bottom inlet? I wouldn't be surprised if the low cooling efficiency of air flowing along the oil pan is offset by decreasing the pressure difference between the top and the bottom of the cowl. If the bottom was closed it seems like there might be more cooling air flowing through the cylinders and the top cooler (and slightly less cooling drag).
kevinh
Postby onex28 » Wed May 25, 2016 1:33 pm
I have a Onex but am using a bottom mounted oil cooler. I don't have Sonex plans but would like to know the Sonex dimensions for the cowling oil cooling inlet. Would appreciate someone posting that info. Thanks.
David W
onex28
Postby ScottM-Sonex1629 » Wed May 25, 2016 9:28 pm
It's not in the Sonex plans...
Look in the AeroVee assembly manual, Appendix A, page 66.
http://www.aeroconversions.com/support/ ... Manual.pdf
Scott Meyer
Sonex 1629 - Sold...9/2019
ScottM-Sonex1629
Postby Sonex1517 » Wed May 25, 2016 10:03 pm
No wonder I couldn't find it when I looked!
Scott is correct. It's on page 66 in that link.
Postby onex28 » Wed May 25, 2016 11:00 pm
Exactly what I need, thanks to all for your help.
David W
onex28
Postby wlarson861 » Thu May 26, 2016 12:04 am
I have not completely closed off the bottom opening but others have with mixed results. Some have had adequate oil temps, others had high oil temps. I put the grill I made on last summer and the oil temps went up, that is only about a 50% reduction to the opening. I took it off and haven't put it back on. I may see what it does in cooler weather but not now with the oats going up(finally).
Bill Larson
N861SX
wlarson861
Users browsing this forum: No registered users and 87 guests
