wlarson861 wrote: After moving to the turbo and top mount oil cooler I left the lower intake open to pass cooling air across the oil pan. The top mount was a bit cooler when normally aspirated but not drastically so. Turbo charged, the oil temps went up a little.
kevinh wrote:wlarson861 wrote: After moving to the turbo and top mount oil cooler I left the lower intake open to pass cooling air across the oil pan. The top mount was a bit cooler when normally aspirated but not drastically so. Turbo charged, the oil temps went up a little.
This may be off-base (because I haven't even finished my Waiex). But have you considered an experiment of taping up the bottom inlet? I wouldn't be surprised if the low cooling efficiency of air flowing along the oil pan is offset by decreasing the pressure difference between the top and the bottom of the cowl. If the bottom was closed it seems like there might be more cooling air flowing through the cylinders and the top cooler (and slightly less cooling drag).
Users browsing this forum: No registered users and 71 guests
