by jjbardell » Fri May 20, 2016 1:15 pm
Bill,
Sorry to hear you are struggling with MAP. Here are my thoughts as to MAP issues. Most are long shots, but I wanted to think of all possible solutions.
- Use Tracerline dye in your fuel to see if you are loosing any pressure at WOT. It will clearly show any and all leaks.
- Check all the spark plugs for proper sealing between ceramic/threads and at the head
- Check to make sure the turbine is spinning smooth
- Check the oil supply going to the turbo
- Remove the air filter to see if that is causing any restrictions to intake
- Secondary timing check. Have you run with just the primary or secondary to see if the secondary is off. I cannot get full MAP at 10 degrees BTDC. I am still making small adjustments but found my performance goes up on just the primary. The mag check at 2000 didn't show me that.
Here are a couple of tests that may help isolate the issue:
Engine idling on the ground. The engine is "trying to breathe" but the throttle is retarded to idle. The result is a significant vacuum in the induction manifold, as the engine consumes the air in the induction manifold but the closed throttle blocks the inflow of air to take its place. In the cockpit, this shows up as a very low MP reading (typically, something on the order of 12" to 15" if I recall. I can check this weekend) far below outside ambient (around 30" at sea level).
But suppose there's a leak in the induction plumbing somewhere between the throttle and the cylinders. Since the ambient air rushes in through the leak, this shows up as a higher-than-normal MP indication at idle…perhaps 17" instead of 14". The engine will also be idling leaner than usual-since the leak lets in more air but not more fuel-so the engine may have slightly higher CHT or even momentarily hesitate upon throttle up.
The other test is to use altitude to check for leaks. Since ambient air looses 1" per 1,000 ft, have you tried WOT at various altitudes to see what happens to your MAP? I would be curious to see your 30" and WOT MAP at 10k ft when the outside ambient is ~19". Does the MAP jump around or bleed off at level cruise? If so, that is an indication of a leak. The turbo is spooling hard but unable to keep up with the leak at high altitude/power settings. Since you are loosing at lower alt, the leak would have to be larger, and the high altitude will grossly magnify it.
Any internal engine issues can cause MAP issues too. Are all of your EGT/CHT still consistent or is one higher/lower than normal? A cold/hot EGT/CHT can be an indication of a cyl not taking a full breath properly.
I'm sure you have already checked:
- Check the valves to ensure a valve tolerances have not gotten too tight and staying open to long
When I was having issues maintaining MAP, it was an intake leak between the T off the turbo and the intake ports. I only found it because after several hours of flying the blue hue of the 100LL was barely visible on the head of cyl #3. If I had tracerline, it would have been easy to spot.
I hope something in here can help you! I'd be happy to get together and play around, even put my new turbo on yours to see how it performs. Just let me know what I can do!
Josh
