WTB: Rocker Arm Spacers
Postby jjbardell » Mon May 16, 2016 9:03 am
Does anyone have two extra rocker arm spacers available? Can pay with Paypal or Chase Quick pay.
Thanks.
N83LJ - Sonex #0864 (SOLD)
jjbardell
Re: WTB: Rocker Arm Spacers
Postby MichaelFarley56 » Mon May 16, 2016 1:21 pm
I'm on the road right now but I'll check mid week when I get home. I'm not sure but I may have a few extras. Those are the thin plates under the rocker assembly?
Postby vwglenn » Mon May 16, 2016 2:30 pm
I'm sure I do. Have to remember to dig through my parts stash when I get home. Free99 if I have the right size. Think they come in three different thicknesses.
They will be used if I have them.
Glenn
Sonex #600
N889AP
vwglenn
Postby mike.smith » Mon May 16, 2016 8:11 pm
Round stainless steel washers have done the trick in the past for me as well. You can get different thicknesses at your favorite aircraft parts store. Make sure they have a large enough diameter.
Postby jjbardell » Mon May 16, 2016 9:10 pm
Thanks all! Kerry was able to find some for me so I'm all set.
jjbardell
Postby vwglenn » Tue May 17, 2016 8:26 am
Cool. I forgot to look anyway.
Glenn
Sonex #600
N889AP
vwglenn
Postby Onex107 » Tue May 17, 2016 12:03 pm
Be careful of adding too many spacers. I saw evidence of the adjusting screws hitting the valve cover. I since have shortened my push rods and removed spacers. It is not difficult to shorten push rods. The nipple end is very hard and you can't damage it. I chuck the nipple in my drill press just above the top edge of the tube, with the bottom end in a hole in a hard board. You can use a hack saw blade or the edge of a small thin file to remove the metal just below the nipple. Some of the saber saw blades are different thicknesses. When you break through the tube you won't even scratch the nipple. Then drive the nipple back down in the tube. It takes about an hour to do four push rods. Removing .020 to .030 of tube length is worth one of two shims.
Postby kmacht » Tue May 17, 2016 12:25 pm
If you can't get them from Sonex in the future you can order them from bugcity.com. It is a local VW shop by me that does mostly mail order parts and doesn't have a problem selling to airplane guys. A pack of 12 shims is $10.95. Part number 21-2310.
#554
Users browsing this forum: No registered users and 87 guests
